POD GO FAMILY
Guitarists and bassists seeking best-in-class tone in lightweight and ultra-portable packages will find it in the POD® Go and POD Go Wireless amp and effects processors. Boasting amp, cab, and effects models drawn from the acclaimed HX® family of guitar and effects processors, they also feature simple plug-and-play interfaces with large color displays, eight rugged footswitches, and cast-aluminum multi-function expression pedals. Plus, with its onboard Relay® wireless receiver and included Relay G10TII transmitter, POD Go Wireless lets you roam wherever your inspiration takes you.
  • Best-in-class performance
  • Simple Interface with large color display
  • Compact, ultra-portable, lightweight design
  • Built-in Relay wireless and included Relay G10TII transmitter (POD Go Wireless)
LEARN MORE
HX Stomp XL
The HX Stomp XL amp and effects processor delivers HX® modeling in a performance-ready pedal with eight capacitive-touch footswitches. It runs up to eight processing blocks simultaneously, and the assignable footswitches let you access and control those blocks in powerful ways.
  • The power of HX Stomp—now with eight footswitches
  • Features the same SHARC® DSP chip and HX Modeling as Helix® processors
  • Eight capacitive-touch footswitches with color-coded LED rings
  • World-class polyphonic pitch-shifting effects
LEARN MORE
HX Stomp
For guitarists and bassists who want professional-grade HX modeling technology in an ultra-compact pedal, the HX Stomp guitar processor offers more than 300 Helix amps, cabs, and effects in a stompbox-sized design that fits easily in the pocket of a gig bag. Whether you prefer to play through a traditional amp-and-pedal setup, or go direct onstage or in the studio, HX Stomp is at once a “super stompbox,” the ideal backup or travel rig, an add-on tone expander when combined with other modelers, and even a multi-channel audio interface.
  • 300+ HX amps, cabs, and effects—run up to 6 simultaneously
  • Additional legacy effects from M13®, M9®, M5®, DL4, MM4, FM4, and DM4
  • Capacitive-sensing footswitches with color-coded LCD rings
  • 4-Cable Method and re-amping connectivity, stereo effects loop
LEARN MORE
HX EFFECTS
For guitarists who prefer to use traditional amp and pedalboard setups, HX Effects features 100+ Helix effects, as well as dozens of legacy sounds from the acclaimed M-Series and Stompbox Modeler pedals—all in a compact and pedalboard-friendly multi-effects pedal. Run up to nine effects at one time. Edit tones with the touch of a finger using eight capacitive-sensing footswitches. And enjoy tremendous depth and ultra-low noise thanks to industry-leading dynamic range, plus analog and DSP bypass.
  • 100+ HX effects for your pedalboard—run up to 9 simultaneously
  • Additional legacy effects library from M13, M9, M5, DL4, MM4, FM4, and DM4
  • Capacitive-sensing switches with LED rings and scribble strips
  • Acts as the command center for your entire amp and pedal rig
LEARN MORE
Line 6 Helix flagship multi-effects processors with HX guitar and bass amp and effects models, speaker cabinets and impulse responses
HELIX FAMILY
Professional guitarists use Helix as the centerpiece for their live performances and studio recordings. If you want realistic analog and tube tone, and powerful sound processing capabilities, Helix is the flagship guitar processor from Line 6. It not only sounds and feels like the original amps modeled, it’s one of the most advanced master controllers for any sized guitar rig.
  • Dual DSP-powered HX modeling engine with 4 discrete stereo signal paths
  • Next generation HX Amps, Cabs, Effects and 3rd party IR import
  • 12 capacitive-sensing footswitches & hands-free Pedal Edit mode
  • Extensive I/O for seamless integration with your entire rig
LEARN MORE
Line 6 Firehawk FX multi-effects processor with HD and XT amp and effects models iOS and Android App editor
FIREHAWK FX
Gigging guitarists that play a wide range of styles and venues, benefit from the incredibly user friendly Firehawk® FX guitar processor. Select HD amps and effects from the largest collection of amps and effects in the Line 6 family. Use a modern workflow to easily edit your tone on a smartphone or tablet via the Firehawk Remote App, and have just the right connections to play any venue.
  • Choose from over 200 amps and effects including 50 HD models
  • Wirelessly control every aspect of your signal chain
  • Access 128 onboard presets plus thousands of tones in the cloud
  • Record to Mac, PC or iOS with the lowest possible latency
LEARN MORE
Line 6 Pocket POD multi-effects processors with XT amp and effects models
POCKET POD
Pocket POD is a portable, battery powered multi-effects that’s packed with over 300 custom presets dialed in by professional, rock star guitar players. Use it in front of your amp—or plug in headphones and jam anywhere.
  • 300+ Presets
  • 32 Amp Models, 16 Cab Models and 16 Effects
  • Chromatic Tuner
  • CD/MP3 Jack
  • Portable Design, weighing just over 6 ounces; only 5 x 3.25 x 2.5 inches
  • USB Connectivity -- Edit presets on the computer with FREE software
LEARN MORE
